Lathe drilling and tapping
I would like to see Lathe drill/tap. I'm pretty sure it's not currently an option and the mill side doesn't work since there are no mill/lathe post processors. I really could use this option. Thanks
5 Comments
Drilling and tapping works in turning machines.
Maybe you are using a old post processor?
But drilling and tapping on the centerline should work fine with the lathe posts.
I've tried every post that comes with it. Simulation works great and when you go to output gcode you get a "failed to post process". I could be totally missing something but I don't believe I am.
Ok,
we would need a little more info to test your problem.
Maybe make a thread here so people can help you figure this out: http://forums.autodesk.com/t5/computer-aided-machining-cam/bd-p/2070
keqingsong
Hey there! Thanks so much for submitting your idea. Unfortunately, this idea did not get a lot of votes from the community, and now is 2 years old. We're changing its status to archived. If you still feel strongly about this idea, you can resubmit it. Check out some idea submission best practices here: https://forums.autodesk.com/t5/community-faq/ideas/m-p/5384681#M44
keqingsong
Status changed to: RUG-jp審査通過
