Show only
Search instead for
Submitted byAnonymouson08-03-201811:16 AM
Status:
Gathering Support
last command
could we use the space bar to repeat the last command and when will you give the canvas more colors in addition to the ones in the present environment.
Bonjour, j'ai installé FUSION 360 sur mon ordinateur et je voudrais changer la langue en Français mais je n'y arrive pas , s'il vous plait pouvez-vous m'aider.
I too would like to be able to directly choose the background color, or even better, upload my won texture or image file to use as a background for the design environment. The color picker should be simple enough
I would also like to repeat the last command. But more particularly in my case, the last drawing mode. In some other programs double-clicking anywhere on the background signals the program to re-enter whatever drawing mode was last used. An example might be wanting to draw another circle after you've exited the circle mode. You might do a few things, whatever-- and then when ready to draw another circle, rather than have to go find it in the menu, just double-click on the background and it goes back into circle mode.
@Anonymous: Have you changed your default settings <your name> -> Preferences -> General -> Pan, Zoom, Orbit shortcuts -> Fusion or <your name> -> Preferences -> General -> Use Gesture-based view navigation -> checked? This might be the reason.
@lichtzeichenanlage It is true that Right-Click + Mouse Up triggers a repeat command function however this is inherently slower than being able to have it key-bound to one (or multiple) key. While the time (and mental work to execute the command) is not significant for a single instance it can easily add up over time. The fact that you have to move the mouse a minimum distance in a specific direction adds unnecessarily complex movement for a vary frequently used (at least for many people) command. Also the fact you have to move upwards can change the flow of your mouse movement if execution of point A (first command) and point B (repeated command) are not in a bottom screen to top screen direction.
I definitely don't want to see this mouse gesture removed however we badly need to be able to key-bound (at least IMHO) repeat command to keyboard shortcuts.
