Jogged Lines on Exploded Views
What would be very helpful is to allow us to have jogged lines in trail visibility when creating an exploded view. Right now, when you are in the process of moving a component, the trail looks like this: Jogged Line.PNG
But when you hit OK, it turns to this. In my current applications, this is not especially helpful.
For an assembly purpose, a jogged line can be far more useful, and convey the order in which parts are assembled.
Any plans for this in the works? I did some searching, and I didn't see it in the forums already, so I hope I'm not duplicating thoughts here.
Thanks!
8 Comments
This is a really great idea +10
Would be awesome to have a simple way of specifying order of operations and dependencies to make this and assembly / exploding animations
k.wildman
You can sort of specify an order on the exploded view by manually moving/exploding them yourself. That's what I've been doing so far, otherwise the auto-generated exploded views just look like a tornado ripped through a whole lot of parts and threw them everywhere!
Yeah the current manual thing takes a ton of work to get close to reasonable output, and the current auto-generated version is pointless
TimeraAutodesk
keqingsong
We need to do this for 2D Drawings first, and have captured this for animations and is currently a future consideration.
k.wildman
@keqingsong, how would this be separate from the 2D drawings? Because that is exactly what I'm trying to do in the end - have jogged lines to appear for my exploded views on my 2D drawings, and exploded views are generated from the animation environment.
For example, a snippet from a quick drawing. I would love to add jogged lines to this to help clarify assembly order in fabrication. I presently manually pull apart my exploded views to best illustrated assembly order due to lack of jogged lines.
TimeraAutodesk
Status changed to: オートデスク審査落選
keqingsong
Good news! This is now available in the latest version of Fusion 360! https://www.autodesk.com/products/fusion-360/blog/december-5-2017-update-whats-new/
