It would be great to have the Hole and Thread tool combined...
This way you wouldn't need to create a hole prior to adding the thread, it could be done in the one step.
24 Comments
Mtimmis-Personal
It would be really useful to include standard thread types/sizes in the Fusion hole command, like we have in Inventor:
At the moment it looks like I would have to create a hole in Fusion, then use the thread command to add a thread to the existing hole. This just adds to the time taken to create a fairly simple feature on a model.
Tags (3)
When you create a hole, it would be nice to have the threading feature built right in. As it stands now, you first make a hole and then thread it. Furthermore, it would also be nice to have through hole options and counter sunk options based on a choosen thread size.
schneik-adsk
Status changed to: Gathering Support
schneik-adsk
brianrepp
promm
Thank you for your idea - This is getting changed to future consideration.  Meaning this is a good idea and will be put into our backlog.  When development gets started on this idea it will move to accepted.
Cheers,
Mike Prom
promm
Thank you for your submission to the Ideastation.  This is a good idea and is being changed to future consideration.
patrik-web
Yes! Moreover, it would free you from having to remember or look up what the correct hole diameter should be for a given thread.
kb9ydn
Adding a thread should be an option in the hole wizard, but threads should still be available separately for making external threads.
C|
Nice suggestion.
I would like to add that the Hole feature could have similar drop downs as the thread dialog for various screw types and sizes, and be able to specify a through hole with a particular clearance fit. Say a through hole for 1/4-20 with a snug fit is typically 0.257 (or F drill size) and a loose fit 0.266 (or H drill)
Tyler
Having a drop down for various threads like Solidworks would be great.
My super-duper ultimate best ever option would be to be able to select a standard fastener, click on a point on a surface, then automagically create a hole through one or more bodies complete with threads as necessary, and have the fastener included with an appropriate rigid joint. This would probably save me 10 minutes per fastener, every fastener, and I'd love you forever.
Sarah
GMDesigns74
Also the ability to locate said hole/thread parametrically without having to create a sketch just to locate a hole.
promm
Thank you for your idea, this is getting changed to future consideration.  When work is started it will be changed to accepted.
Mike Prom
Yes, please do not wait for Christmas, my birthday, or anyone else's birthday to bring this to life.  Fasteners are so basic to so many designs and they currently take too much thought and effort.
promm
@Anonymous,
Have you used our McMaster-Carr insert tool? You mention the amount of effort it takes to create fasteners and this will help.
Mike Prom
Sorry Mike, meant to phrase it in regard to the creation and 2D call out of the hole details that is currently too cumbersome
The McMaster and Misumi integrations are one of my favorite things!
Bill
promm
@Anonymous,
In regards to you 2D hole call out I am assuming you are referencing drawings.  What details do you require for hole / thread notes in drawings?
Cheers,
Mike Prom
robduarte
This is similar to another highly voted request - can they be lumped together? I think we'd see more votes for this type of feature at that point.
promm
@robduarte,
Which idea are you referring to?
Cheers,
Mike
