Intuitive Screws
Intuitive Screws
Models, wich has a lot of component, those need to be screwed together are in almost every project. It will be extremly helpful and intuitive to have a function as an "Ultimative Intuitive Screw Wizard" (U.I.S.W)
Solidworks has since years the funtcion of the Hole wizard, which I mentioned a couple of months ago, and it needs to be on Fusion 360 too. But an UISW will be amazing to. Lets say, be have a simple object, which has 4 components. This 4 components need to be screwed together with 4 screw each conection (this are 12 screws for example). The user made already each of the **** holes manually and wants not only to give the "Join" command. He/She wants also to put the "market-existent" screws of 2mm on each hole. The UISW could help here: The user opens the command and choose the screw of 2mm. Then comes the funny part: Lets put a filter on the UISW saying: "in each hole of 2mm diameter and 15 mm depth, put a 2mmx20mm screw inside it...and in each hole of 2mm and 20 mm depth, put a 2mmx25mm screw inside it....and BUM...each **** hole has a screw, which fits perfectly acording to the depth of the material, that needs to be screwed.
This will improve a lot the work process, make realistic models and conections, and visualize as a master the exploded views on the drawings from each element.
Thanks!
2 Comments
colin.smith
Unfortunately this idea did not get the support of the community and as such we will not be pursuing it. Please feel free to rework and resubmit this one down the road. Thanks for taking the time to submit your idea. Due to the low strategic fit, we have decided that we will not be pursuing this one at the given moment.
colin.smith
Status changed to: RUG-jp審査通過
