When using INSPECT>COMPONENT COLOR CYCLING TOGGLE, with complex assemblies, different components often are assigned the same color, causing difficulty in interpreting the assembly when these parts overlap. An associated issue is that for people with partial color blindness, some color combinations appear with little or no color difference.
I propose that the INSPECT COLOR feature allow the user the manually override colors of individual components and bodies and select a more suitable color from a palate of a dozen or so colors that are wide-ranging in hue. THANKS
