Inside corner relief function in Modify menu
It would be nice to have a Relief tool for inside corners of solid models.  It would be an option in the Modify menu, like chamfer and fillet.  One might select a line on an inside corner, enter a width and depth of the relief and voila.
See discussion: https://forums.autodesk.com/t5/fusion-360-design-validate/adding-inside-corner-relief/td-p/7972599
2 Comments
Aussie-Alex
There is an app available for making Dogbone u/cuts in internal corners, I use it for laser cutting models and it works fine.
See demo and download at:
I would use this function (Inside Corner Relief) so often. Right now I am going through an overly manual process of drawing circles tangent to corners and cutting away the material. I like the idea of implementation akin to a chamfer/fillet tool.
