Message 1 of 10
What is the easiest method for adding an inside corner relief? Often with metal parts one relieves an inside corner (with a cutoff wheel or slitting saw) in order that the corner radius does not interfere with a close fitting part. Is there an easy way to realize this in Fusion 360? I have been going to the side profile of the corner and drawing small rectangle at 45 degrees to the edges and then extrude-cut that rectangle down the corner. This is tedious and also prone to being screwed up if the corner dimensions change.
Seems like there should be a Relief function under the Modify menu, but I am wondering if there is an easy way to do it that isn't obvious to me?
-Tom
