Hi All,
Is is possible to insert prepared blocks other than the title block into fusion 360 drawings? For example, sometime I need to insert a finish block with the coating type, color, etc. of a part being detailed. I am also a registered PE and need to insert my stamp block. The finish could be done with a note, but the PE stamp carries legal requirements for shape, size, text size etc and can't be done with a note. I have a DWG block for this. I could probably insert my Jpg stamp into the .PDF output but, it would be good to insert it into the drawing itself. It doesn't look like this is possible. If not, it should be considered. This functionality could also be used for a revision block.
I started this thread in the support section. Here is my first post:
https://forums.autodesk.com/t5/support/insert-blocks-other-than-title-block/m-p/7138688#M3920
Thanks!
Mark-
