Improvements To Sketch Text Formatting
I think it would be useful to format the sketch text settings more like how "text boxes" are formatted in things like Adobe and Microsoft Products. Not only would this be more intuitive from a user's perspective as most people are familiar with how they work, but it would also make it easier to actively change the text if you need it to. For example, in the image below, the dashed border I would think to be a standrad "text box" like in the programs I mentioned above. However, when I change the size of the dashed box, its height controls the size of the letters, its angle tilts the text, but its width does nothing, as shown in the images below.
Nothing allows me to wrap the text around to a new line, unless I press enter at a specific location within the "Edit Text" window. With lots of text to deal with (I just repeated a bunch of "a"s as an example), finding the right spot to hit "enter" to form a new line can be tricky, and working with text in Fusion 360 would be a much more intuitive experience if the yellow dashed text box worked like a text box that people are used to dealing with (i.e. while Fusion is a new type of design tool, there is no use reinventing the wheel on this specific concept). Perhaps the width of the text box could set the marker for where text should wrap around to the next line, like in other products.
17 Comments
I'm with you 100%.  It's a little mickey mouse as-is.
This is come up before and is a huge oversight as-is. Should be immediately promoted to future consideration even if it doesn't get 10 votes
gah came obviously not come
The entire text handling engine(s) at Autodesk needs a serious overhaul.
You have to be careful about your font choice, they can only be TrueType as OpenFont is not fully supported and can cause all kinds of alignment and spacing issues when modern fonts have multi-lingual support. The current engine really limits adding text as part of an object in 3D design, as well as simply labelling.
Apple has a good text engine, but Autodesk needs something cross platform. Adobe has a great text engine, but I don't think they'd license it, but if they ever merged it would be "GREAT!"
Until then, let's hope the work they are doing in 3D and sculpting leads to some improvements in the core text engine they use across their product line. It would help them with localization and the ability for improved text handling around the world.
I honestly cannot believe how much of my life is spent annoyed by trying to get text into Fusion.
Currently what I do is:
-generate text in Illustrator with the document units in inches
-covert text to an outline
-scale the outline uniformly to the desired height
-draw a bounding box around the text with two corner connecting lines
-export as a DXF with 1 unit = 1 inch
-import the DXF into a Fusion sketch, get this error and be really confused
-In Illustrator, pre-select the objects you wish to import, export as DFX with 'Only export selected text' enabled
-import the DXF into a Fusion sketch, have it import upside down, curse
-go back into Illustrator and flip the text upside down, re-export, re-peat
-it kinda works
-add a point at the intersection of the two corner lines and make them construction
-move the sketch using that point as a reference
-do what you're gon do with it
Very much agreed.  I do a lot of panel layouts for test eqipment.  Simple features like "center justification" within the text box and the ability to set a default font and size would be very helpful.  Multi-line text would also be nice.
promm
Status changed to: RUG-jp審査通過
Thank you for your idea, this is getting archived due to the details in the request.  We are working on improving our text formatting, however the request to have the level of functionality that adobe and Microsoft is something that will take a long time to work towards.  Please provide what you think would be a single improvement that we can prioritize that will improve your workflow.
Thank you,
Mike Prom
Hi Mike,
A single improvement would be to allow for text wrapping depending on the width of the box, as per the example I described. So if the width of the box becomes smaller than the width of the text, the text will wrap onto a new line.
Alex
Even basic text wrapping would prevent me from wanting to hang myself when I use fusion 360. Extremely daft not to have it - heck! even notepad has it from crying out loud.
rapiddsol
Agreed!
Multi-line text is a must have and should be top priority for the development team.
OP thanks for starting the dialogue.
I also would be extremely pleased with being able to have the multi-line text capability.  Very difficult to achieve a good looking text engraving as the system works now.  Hopefully this will be implemented very soon.
teamS3DB5
Observer
Please add Multi-Line Text Please !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Two years and still not implemented...................
Where is my Multi-line Text? Its been over 2 years?!
There should be a Centering feature too.
I shouldn't have to use my measuring tool a thousand times to make sure text is lined up or centered.
Fusion 360 often makes the simplest of tasks messy and laborious. Not including this multi-line feature is purely a lack of foresight.
lubos.ulovec
simple multi line text would be nice. Yes we can work around but... I know you have million other requests for things but please forget some aggravated members above 😉 and consider it, thanks a lot.
Best Regards,
Lubos
How are we still waiting on this? Its been over 3 years. This wonderfully brilliant group of people could have solved the problem for fusion by now. Just add the multi-line text, please!!!
tw2ZDRJ
Multi line text is a must..... you're killin me smalls.
