Improve file management / move copy delete in an account !!!
1. often files are so called being used. I just logged into my account into a folder I did not touch for months.
2. in 2015 we should be able to drag n drop files into a folder and not have to be forced to use a RMB menu
3. in the folder dialog selecting a folder is only possible by double clicking the folder. most users would LMB click select a folder and then say move.
3 Comments
It'd also be kinda nice if files (/designs) in different projects weren't treated differently than files in the current project (not that I've managed to actually use embedded models in practice yet)
haughec
Hi Claas,
We currently don't allow you move any design that has - or has had - external references.  We are actively working on lifting this restriction, (as well as allowing cross-project references) but I don't expect that work will be complete until after the first of the year.
I agree with your observations on the data panel experience (drag & drop, etc), though we haven't started any work here yet.
Moving this to Future Consideration.
Charles
haughec
