In complex models, it can sometimes be a pain to create planes in space e.g. when you want to make a cut somewhat normal to an area on an organic surface. It would be very helpful if a plane could be created just from the current camera angle, so you could just "look" at your object from the angle you want to cut, and the plane is created there automagically 😉
Thanks!
