How to engrave a sketch
I would like to see the ability to select an entire sketch when doing engraving in the Cam environment. Imagine making a pallet for a CNC machine to cut 16 aluminum rulers at a time, and the ruler need gradient marks every 1/32 of and inch over a 12 inch span on the top edge and bottom edge of the ruler. In the model environment I just drew a sketch of the gradient marks because they are small marks and I am going to you a single point tool to cut the feature. That means I manually have to pick one by one 768 single sketch segments for each of the 16 rulers. Instead of just being able to click on the whole sketch. Or make a containment boundary like for drilling and anything in the boundary is highlighted for geometry to use for the tool path.
