I think it would be useful to have in the HOLE COMMAND an option where you can create a hole that offsets the start and end of the thread. I know you can offset the thread but it starts the offset from the first plate and i think it would be more useful for the offset to start from the bottom (invert offset). Example, i am trying to fix 3 plates, the first two should have a clearance for the bolt to go through and only the third plate should have the threads so it can grab the bolt.
