Hole function snap points
The Hole function on Fusion 360 is a good tools, but it need some "weapons".
One of the basic should be the snap option for the holes. One choose the face of the object, and the Hole appears on it, but it need references ponit to snap on it, like middle pont, edges, etc. Maybe is possible now to edit this adding constraints after doing the hole, but a snap funtion on the hole wizard will improve the work.
Another "weapon" should be a Hole wizard as SW, with ISO dimensions and forms.
4 Comments
TrippyLighting
You can dimension the distance of a hole from an edge while in the hole creation dialogue, so reference points are not necesarily needed.
If I need to place more than one hole at the same time on the same face, I usually create a sketch that provides the snap points and then place the holes on those snap points. This provides ultimate flexibility.
If you want to place a hole in the center point of a face you can do that already.
keqingsong
Hey there! Thanks so much for submitting your idea. Unfortunately, this idea did not get a lot of votes from the community, and now is 2 years old. We're changing its status to archived. If you still feel strongly about this idea, you can resubmit it. Check out some idea submission best practices here: https://forums.autodesk.com/t5/community-faq/ideas/m-p/5384681#M44
keqingsong
Status changed to: RUG-jp審査通過
moth3r
Every object/function should be 'snappable'. I don't even know why we are discussing 'hole' individually when snapping should be already implemented on the top level by default. You should improve User Experience Design philosophy instead leaving it to the users to deal with problems on individual basis on forum.
So yeah it's kinda retarded I still favor to 'circle' around. It's almost the same scenario like the text tool, so many unfinished, broken or inefficient tools. User scenarios like this one should not be archived, you are just piling dust under carpet.
