Is there a way that this can be added to make life simpler and without referring back to the print for manufacturing. So here goes. When selecting a hole it would be helpful if there were an option to select depth to full diameter of drill or to drill point. It can be listed both ways depending on who drafted the blueprint. This would allow the machining CAM process to select drill to the hole bottom every time. It would be contingent on what was already selected on the design side. Additionally if full diameter was chosen the drill point angle could be also factored into the equation. This would also give the model a more accurate representation. Currently if the hole is to drill point I have to calculate out the drill point or have to remember it is such when I go to CAM it up...
Thanks for considering,
Scott
