Hidden version infos
If you save a design fusion displays a dialog you can enter a version info.
But if you work with versions and need the version infos about, you never find them.
In data panel under versions, no info text is shown.!
Going to A360 to the project and look in the "Last activites"-panel, no version infos!
Dive in to the A360 project detail page, no version infos!
You look around and find this little select box control near the design title. And if you open it you can see your entered version infos.
Thats not really clever for a system that is based on VERSIONS!!!
PLEASE place that version infos so, that the user can easily  find them and add the last save infos to the design item in the data panel!!! 😉
7 Comments
Hey Peter,
Are you talking about this?
If so, Kudos! I'm missing that as well!!
macmanpb
@Anonymous,
yes that's the point. You can't see what changes happend, you need to go to A360.
@macmanpb
I know that version control (vc) is new, but you are not able to see it there at all (vc history included).
That brings me to the idea to treat save points as commits...
keqingsong
Status changed to: オートデスク審査落選
In this coming April update, you'll see your comments in the design info in the data panel 🙂
@keqingsong Awesome!
keqingsong
macmanpb
Thank you team and @keqingsong!! That helps allot 🙂
