Show only
Search instead for
You can use Ctrl to select several file then right click and Move\Copy to another project of folder. On the move\copy dialog you have the option to create new projects or folders at the same time as the move\copy. The only restriction will be if the designs are linked the you will only be able to move to folders within the current project.
