Show only
Search instead for
Yes, let hope this get implemented soon. I have dual screen setup on my laptop to help with the screen space issue. Some of the task bar operations in the current screen are good and should be kept. For instance, the automatic drop down menu ("Fly-out") when you mouse-over the task bar after your first mouse click on the task bar. Additional use of Fly-outs and Hidden Screen Tabs would be useful as well. Popup screens should not be in free space on the canvas and should be controlled with a tab around the perimeter. The exception to this might be Popup windows with and error or critical info.
I have tried to do it so many times without success, maybe my computer has some problem. Anyway, the 2 top bars could merge as it doesn't have many things n will save space, including auto hiding bars will give much more space. Thnx!
Thanks for sharing your ideas. We have several UI projects underway that should get us closer to a cleaner UI with more real-estate, which will also improve the sketch palette as well as UI performance. Blending the 2 bars you've indicated is also something we're looking into, but may not happen in the short term. We'll keep you posted on our progress. Keep an look out for our roadmap update sometime in Feb - we'll be sharing more details there.
I'm using a second screen on my laptop (which is running windows 10 pro), and would like to be able to move the data panel off the screen where I m running fusion. Which will increase the available space in the fusion window, while still allowing access to the data panel.
I would also like to be able to resize the Data panel, precisely to show things like very long file names.
At the moment you can only hide/show the data panel. Unlike the browser for example, you can hide/show the browser as well as move it around.
You know what would be great? An Inventor style minimalised sketch palette. I don't need the labels on the tools anymore, just the icon is enough, and the extra screen space would be more helpful.
I agree with having the option to disable text. Also maybe some permanent toolbar location instead of floating, but not some 'click to see' button thing like create, sketch, modify. Too much clicking needed already.
