Fusion 360 Frame Generator
I really loved the frame generator in inventor i always use then in making structural frames and now i am using Fusion 360 its time consuming making every profile sketch of each frame member. So having said that i really loved the frame generator to be integrated in fusion 360 thanks,
84 Comments
mail
@matthew.nichols
im not aibled to install you plugin.
i copyed everything into the folder, fusion founds it but where do i find it ?
Where is the button to click on ?
What i am doing wrond
Anybody who can help ?
regards
Elmar
ignaz111
copied the Folder, started in Fusion, but there is no "Button" to start.
A Frame Generator in Fusion 360 is very important for us. I stopped my work with Fusion because of Building Frames are taking to much time.
Please bring a tool like FG of Inventor or SolidWorks to Fusion
thanks for your work @Anonymous
Ignaz
@ignaz111  @mail
it may not run on startup at first.
go to the tools tab and go to the scripts/addins command.
click on the add-ins tab: find Nichols360-FG and hit run if it doesn't have a dotted circle to the right of it.
then the command is on the tools tab.
mail
@matthew.nichols
- I copyed into the correct folder
- If i open the skript/plugins panel, its listed under plugins without a dotted circle
- After click run, nothing happens and i can not find it under tools.
- After opening the script/plugin panel again, there is still no dotted circle.
Please help !
