I organize my tools in the toolchanger based on the CAM operations. So there is a minimal time wasted between changing tools. So for example...cam op 1 -> tool 1, cam op 2 -> tool 2 etc.
There is of course a difference between the used tools for each program. Example: cam op 1 -> tool 6, cam op 2 -> tool 1.
At the moment I re-order the tools in the toolchanger for each program. Which is fine. But changing the tool number in the tool library is slow. It would be very helpful is there was a faster way to change tool numbers.
Sometimes I use a text editor because it's faster than changing everything in the tool library. But if it was built into Fusion (without changing the tool number in the tool library) it's less prone to errors
