Extrude - Operation Selection
When you use the Extrude command the software makes a "best guess" at whether you want to Join/Cut/Intersect/New Body/New Component.
If you select what you want to do in the dialog box before you extrude it ignores your request and goes back to the "best guess" method when you start extruding.
Could the software be configured so that if you've selected the type of operation before you extrude that it recognises that you know what you want to do and stays with that selection once you start extruding?
A minor irritation in what's a great piece of software.
Best regards, Steve Cox
2 Comments
keqingsong
Hey there! Thanks so much for submitting your idea. Unfortunately, this idea did not get a lot of votes from the community, and now is 2 years old. We're changing its status to archived. If you still feel strongly about this idea, you can resubmit it. Check out some idea submission best practices here: https://forums.autodesk.com/t5/community-faq/ideas/m-p/5384681#M44
keqingsong
Status changed to: RUG-jp審査通過
