Etching mask
Etching mask
In Fusion360 I draw a sketch for a logo, a trademark and a sentence.
Then I would want to create the etching mask from my design.
I didn't find any tool in Fusion.
I thougt it would be as easy as saving it in Fusion and openning it in InkSkape but it isn't.
When someone wants to create an etching mask he needs to print it and the only fileformat that enables the same result everywhere is PDF.
The DRAWING toolset already produces PDF and enables to place views on a sheet.
In fact an etching mask is almost a section view with filled parts.
Then if someone wants to deal with double-sided etching mask he would produce the section views with the etching mask setting.
Don't forget there are positiv and negativ etching masks.
Positiv : Etching white
In current section view you got 3 types of draw :
Background
Cut
Nothing
Positiv etching mask :
Background is White
Cut is Black
Nothing is White
Negativ etching mask :
Background is Black
Cut is White
Nothing is White too.
Need to have cross marks at view edges.
Please could you add etching mask in DRAWING toolset ?
Regards
1 Comment
mbellahcene
Let's work in Inkscape for Etching masks.
Please let us save a sketch as PDF or SVG, may be great for many use-cases.
Regards
