Error: component behaving as read-only, refuses to boolean or tweak
http://a360.co/1T3dJ19
- made subassemblies
- made master assembly
- realized I needed to cut a hole in one part
- created a cube with plane on one side of the target body
- when i extrude, error says "no target body found to cut or intersect!"
- i extrude as new body
- i manually attempt to boolean shapes.  cannot click on target body.  Apparently I can't click on ANY component bodies, they're off limits.
What am I doing wrong here?  In other projects I built the bodies from the ground up in a single file and they could be boolean'd.
2 Comments
keqingsong
Hey there! Thanks so much for submitting your idea. Unfortunately, this idea did not get a lot of votes from the community, and now is 2 years old. We're changing its status to archived. If you still feel strongly about this idea, you can resubmit it. Check out some idea submission best practices here: https://forums.autodesk.com/t5/community-faq/ideas/m-p/5384681#M44
keqingsong
Status changed to: RUG-jp審査通過
