This page has been translated for your convenience with an automatic translation service. This is not an official translation and may contain errors and inaccurate translations. Autodesk does not warrant, either expressly or implied, the accuracy, reliability or completeness of the information translated by the machine translation service and will not be liable for damages or losses caused by the trust placed in the translation service. Translate
Emboss Feature
Emboss Feature
I think it would be great if Autodesk could make an Emboss feature somehow similar to the feature you have in Inventor:
https://www.youtube.com/watch?v=NRAIIM4_KRI
It would be great if we could use this feature with text, sketch and imported svg files.
CA
62 Comments
I will try the workarounds but a genuine emboss tool for curved surfaces will be fantastic. One click, one SVG embedded on a surface of your choice. To all decorative artists this would be an absolute godsend.
I just tried installing the SurfaceText AddIn and can't seem to get it working. I am on a Mac. Not using the App Store Version of Fusion 360. I've added the SurfaceText folder to ~/Library/Application Support/Autodesk/Autodesk Fusion 360/API/AddIns/SurfaceText/SurfaceText.py
It shows up in Fusion 360. But when I click run, the dialog disappears, and the suface text button is not available under the create menu.
It doesn't seem to actually be running as indicated by the little loading circles. I've attatched a picture to show what I mean. Any ideas on why I can't seem to get it running are appreciated.
Thanks!
James
undefined
Hi there,
From my experience and seeing from the post on the forum on the issue of projecting sketches onto curved faces, a feature similar to SolidWork's Wrap feature or Inventor's Emboss feature is much needed.
Tim
Tags (3)
I agree....  Incredibly that you can't wrap text onto a curved surface and then extrude it to create embossed lettering.  This is avaiable in every basic vector graphic tool from Paintshop to Photoshop and has been a feature in those tools for over 15 years now.
jlotuaco
Please implement this feature.  This capability has been requested many times for over a year now.  The work around that I have seen is such a waste when I can create the same results in Solidworks in three steps without dealing with multiple bodies.  All that should be required is Create Sketch with text -> Choose face to project onto -> Specify dimension of emboss/deboss -> Done.
I have had to migrate to Rhino for lack of this feature. A **** shame as fusion is a joy to work with.
maruska
Been reviewing some of my old votes. This one is at the top of my list. I hate that I have to jump into other packages for this one feature.
Bump. +1!
Why stop at text? Surely any shape or design should be able to wrap around non planar surfaces?
haughec
Adding an Emboss tool is definately on our radar, though it's not a current priority.  Marking this as Future Consideration.
Charles
haughec
Status changed to: Gathering Support
promm
Thank you for your idea, this is getting changed to future consideration.
Internal use FUS-24793
Thank you so very much...this opens fusion up to so much decorative work
for artisans and jewellers.
carlos.alves9SA2V
Thank you for considering this feature as a future enhancement.
It will be even greater to use Fusion 360 with this Emboss Feature.
I cannot for the life of me think of one single feature that could open up fusion to a whole new set of users. Without the ability to decorate surfaces regardless of how non-planar they are, or to create detailed decoration on a planar surface and then manipulate that surface into new shapes, every artisan and jeweller is *severely* hampered. I use Rhino but would switch to fusion in a heartbeat if a range of embossing options were open to me, as well as a flow to curve function.
promm
I have a question for the people on this idea.  There are two solutions we can explore:
1. Emboss, where your wrap an image around a face
2. Wrap to face, this is different in that you could wrap a sketch around and object, such as a cylinder multiple times.
Which one would you like to see first?
Thank you,
Mike Prom
jlotuaco
Definitely wrap sketch to a face to drive a feature, as that has far more used than simply wrapping an image around a face.
Oceanconcepts
Mike, can you be a little more descriptive as to the distinction?
I'm taking it that Emboss would be wrapping a bitmap or other image, to make something like bas-relief? And wrap to face would enable putting a sketched outline on the face, that could be used for extrude/ cut/ combine type operations? If that's the distinction, I would opt for wrap to face- but do I have it right? Or is it just about how the image is fitted to the face?
Ron Russell
Wrap a sketch around a face. Undoubtedly. Far more useful to an artisan to
have something workable happening to a face; after all we are working with
3D printing rather than presenting mock ups. Even better would be the
ability to emboss a flat area and then wrap or flow the resultant face
around a predefined path. That would make life a lot easier - and be kinder
to computing resources - than working directly on irregular faces. Check
out Rhino's flow to curve and flow to surface. They really have this one
nailed.
carlos.alves9SA2V
I would say that "wrap a sketch around a face" is more like to be the most valid idea to me.
it would be helpful if it could work on double curvature surfaces.
maruska
Agreed - I really need to be able to draw something in a 2D sketch and have it map to a ruled surface (cone, cylinder, etc). Compound surfaces would be a bonus - but I know from years of using Alias's "map to surface" tool - this is a tricky proposition.
- having a the ability to create a ruled surface and unwrap it to a 2D sketch would be greatly appreciated (like Rhino).
I'm working on a project currently that requires both work flows.
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
