DXF export with layers
it would by nice if the sketch2dxf exporter could create different layers for construction lines and normal geometry.
At the moment I have to delete/assign them manually
Thanks Dirk
1 Comment
bkgoodman
This is a NIGHTMARE not having this functionality. Not only are my sketches inside to look at because I can't separate (and turn off) things as separate layers, but then when I export to DXF, I get all the construction lines, etc.
My end use-case is to cut parts on a laser where I have to export as DXF - so my DXFs out of Fusion are useless, which means I can't use Fusion for anything I need to run a part of on the laser.
