Greetings,
While checking out simulation workspace I noticed there is no drop test simulation available as I tried to leave my component unfixed to run the computation. Therefore I was hoping to see an icon on the constraint options that allow the user to specify height of entire component from ground level relative to a plane parallel from the component to ground. Since the toggle gravity function is already available in the load option, no additional function is needed there. The computation that is solved right after meshing will then be that of a drop test simulation.
Do correct me if I am wrong. Besides, I am having trouble understanding the 'prescribed displacement constraint' function in the constraint options, so what I am asking for may already be doable using the aforementioned technique.
Sincerely,
JerHan
