I would like to be able to create multiple new manual nc operations with about 5-10 lines of code and save them as templates that I can name myself. For instance, I need to be able to write code to retract a machine to it's Z zero position, then position it to an X and Y, then rotate an indexer. I typically run CNC horizontal mills with an indexing tombstone, so I need to keep the spindle as far away from the tombstone when indexing, as it indexes in rapid feed only. I also like to position X and Y in a place of my choosing for the next operation. I know I can just edit the posted code but I dont want to do that everytime I change feeds and speeds or a toolpath.
I have used the "Actions" and "Pass Throughs" options, but they are limited to one liners and you cant save them for use later.
Thank you, and keep up the great work, I am loving this software so far!
Korianna Slawnyk
