Drawing - Section view enhancements
Request to improve or enhance drawing section views in Fusion 360:
1)  Section line is associated to drawing view objects or features. E.g. a section line through a hole should update when the hole moves.
2)  Improve inference projection when creating Aligned section views. E.g. sketching the section line at a non-orthogonal angle through a feature. A point can be acquired, but you cannot continue the inference angle lock.
3)  Add support for section participation. The user should be able to select which components are sectioned.
Jerry
5 Comments
JBerns
Also should use the correct linetype for section line.
- Jerry
JBerns
Correct the issue showing a vertical line in the section view that represents a vertical segment in the section line.
TimeraAutodesk
josh.sapp
It would be handy also to be able to change the section letter for multiple page drawings.
TimeraAutodesk
Status changed to: オートデスク審査落選
#3 was implemented last month - let us know what you think!
