I am officially using Fusion 360 for mechanical engineering daily - I am really enjoying its power and flexibility.
I realize there are updates coming to the Drawing Module, but the inability to export a PDF with typical drawing line weights is very frustrating.
The exported PDF drawings from Fusion look like a 2nd graders coloring book. Having to export a DWG, then open it in DWG TrueView, changes layer line weights and re export as a PDF is very time consuming and frustrating.
Can you please change the default drawing layer line weight from .50mm to something like .15mm when exporting PDF?
Regards
