Drawing from a selection set
If i have a big assembly and i need to crate some drawings based on a selection set for example:
An option in the insert time of model into drawing that we can select all entire model or just a simple selection set:
that will be very handy.
4 Comments
HughesTooling
You can sort of do this now. In the model workspace use your selection set to select the components, right click and select create drawing then on the create drawing dialog ether use Create New or select an existing drawing.
Mark
Hi @HughesTooling, maybe I missing something, but I can't find this option:
Leo
HughesTooling
I can't get quite the same menu you have but it could be the selection set needs to be just components. It might work with components and bodies as well, not sure.
Tested a bit more and I think you have only selected bodies and faces, no components. I think if you make sure you have at least one component selected it should work.
Mark
That's right @HughesTooling, I just needed to change my priority selection to Components, in selection Filters,, is not the same thing but I can use this way right now.
I will still with my idea, if we have this same thing when create a drawing, will be way better.
Thanks a lot for the tip!!
