cancelar
Mostrando los resultados de
Quiere decir:
do away with those mirror folder or make them deletable
I am somewhat annoyed by the fact that folders break any fast delete/remove function in the browser.
First you cannot select 6 objects at once when 2 are in a mirror browser! Why?
I have to select the objects in the browser and remove them and then in the folder and remove them. Labor intensive!
Then I cannot delete/remove the mirror folder in the timeline. Why? makes no sense.
I am really not sure if it makes sense to even put them into folders when that breaks the object seletion mode in Fusion.
https://drive.google.com/file/d/0Byzv_NlyKp_2b29pak9xcExWTWM/view?usp=sharing
so why not
A) when selecting a folder select the content as well
or
B) also make folders deletable!
4 Comentarios
I'm convinced that the reason we can't delete them is because the object graph gets corrupted and leads to null pointers or something similar but it's incredibly annoying. Anyway nothing should actually be deleted - it should just be flagged deleted and not shown.
I kinda see where they're going with the mirror folders but somehow those never quite work and always get wonky for me.
brianrepp
El estado se ha cambiado a: Gathering Support
colin.smith
This item has been archived due to a lack of votes. If you feel this item is important feel free to create a new idea station item.
colin.smith
El estado se ha cambiado a: RUG-jp審査通過
¿No encontraste lo que buscabas? Pregúntale a la comunidad o comparte tus conocimientos.
Enviar idea
