This page has been translated for your convenience with an automatic translation service. This is not an official translation and may contain errors and inaccurate translations. Autodesk does not warrant, either expressly or implied, the accuracy, reliability or completeness of the information translated by the machine translation service and will not be liable for damages or losses caused by the trust placed in the translation service. Translate
Dimension drawings - master layout, copy and paste, significant digits
A feature (like Adobe InDesign) where you can create a master template for dimension drawings.  That way, it appears on every page of the document.  For example, you create a text box in the corner that says something about material or details.  It appears in the exact same spot on each page.
Also, you should be able to copy and paste dimensions and text.
Lastly, when you set significant digits to 3 places, a dimension like 0.480 shows as 0.48.  Even if the last digit is 0, it should be there.
2 Comments
keqingsong
Hey there! Thanks so much for submitting your idea. Unfortunately, this idea did not get a lot of votes from the community, and now is 2 years old. We're changing its status to archived. If you still feel strongly about this idea, you can resubmit it. Check out some idea submission best practices here: https://forums.autodesk.com/t5/community-faq/ideas/m-p/5384681#M44
keqingsong
Status changed to: RUG-jp審査通過
