dimension a diameter from a centerline
It would be nice if you could dimention a diameter off a centerline in a sketch.   for instance, when I click a construction line and another sketch point,  if I keep the mouse on the side between the constuction line and the other point,  it should place the short dimention, but if I hover the mouse on the other side of the construction line,  it should snap to a symetrical dimention or a diameter dimention that extends the dimention line an equal distance across the construction geometry.
SWx  added this feature a few years ago and it is very usefull.  hopefully my description makes sense 🙂
Thanks,!
7 Comments
catot
It is currently possible to dimension a diameter off a centerline, although not exactly like you describe it. Just remember to right-click before poistioning out the dimension on the sketch, and choose Diameter Dimension in the menu (same functionality as in Inventor).
madengineer13
Thanks  Catot!
That solution works fine for me.   I'm still getting used to it, but it has one advantage that I can see.  In SWx  you have to use a construction line or a centerline to get this feature to work.
It looks like fusion will do it with regular lines, which in my mind makes it more powerfull.
Thanks for the tip!
n.schotten
RMB for every diameter line is way to time consuming. And prone to mistakes. Having a defined centerline makes it simpler and faster. Why else would most others (inventor, SW etc) have the centerline option in their sketches. It works faster, defines the axis of rotation and is reusable for dimensioning.
alexandwirtz
Hi, it would be nice if the dimension would be placed on the other side of the construction line, not like in the picture attached. if you work a lot with symetric sketches, this would be better. -or is there already a way to switch the dimension to the other side?
Alex
catot
@alexandwirtz Choose the line you want to be the centerline first, then you will get the dimension to display how you want it to.
Edit: The line you select first when dimensioning will be the centerline.
alexandwirtz
alright, thank you! that works! 🙂
colin.smith
Status changed to: RUG-jp審査通過
