Tabular Drawings or Cut Drawings
This Idea is similar to
"Custom Part Properties, Templates and Tables in drawings" by PhilProcarioJr
I work with wooden parts so many of my components have the same section but different lengths and different end conditions.
I would envision this function as follows:
Pick a component that has all the common characteristics to be the base component.
Pick into creating a Tabular Drawing.
Specify the number of parts and the number of variables.
The base component shows up in the first line with its part number in the first column. Each of the variable fields would have letters above them.
Go through the base component and dimension.  Whenever a dimension is to be a variable, select the variable field letter and the cell is populated with the model dimension value.
For each variation of end condition, a letter option is selected.  This would then allow the operator to include a detail view on the sheet.
The table then could be exported into a comma delimited file.
3 Comments
colin.smith
Unfortunately this idea did not get the support of the community and as such we will not be pursuing it. Please feel free to rework and resubmit this one down the road. Thanks for taking the time to submit your idea. Due to the low strategic fit, we have decided that we will not be pursuing this one at the given moment.
colin.smith
Status changed to: RUG-jp審査通過
I developed a work around and almost have what I am asking for.If someone is interested, I can show them.  It may be a very short piece of code to make it smoother.
Allan Steinkuhl
