Design intent parametric inference engine
Internal patterns and symmetries are at least as useful as reuse of components (arguably more so because they require less effort, planning, and mental bookkeeping)
To be a first class product, F360 needs much better support of symmetry and patterning.
In principle, parameters can be used to achieve that, but it requires great care and effort to manyally create new parameters with each operation and manually setting values to parameters is extremely error prone and almost guaranteed to fail in nontrivial designs.
It would be insanely awesome if F360 could infer the user's intent automatically or explicitly through adding symmetries, patterns, and complex constraints
To see what you're missing and what could be, please watch this on synchronous design intent
https://m.youtube.com/watch?v=5nPQOalmlrc
3 Comments
If you haven't seen it, this is insanely awesome - watch it !
keqingsong
Hey there! Thanks so much for submitting your idea. Unfortunately, this idea did not get a lot of votes from the community, and now is 2 years old. We're changing its status to archived. If you still feel strongly about this idea, you can resubmit it. Check out some idea submission best practices here: https://forums.autodesk.com/t5/community-faq/ideas/m-p/5384681#M44
keqingsong
Status changed to: RUG-jp審査通過
