Design History : Hover Over NEEDS more info... like: Direction, Distance, Taper
Improvement Suggestion: Design History Timeline...
When I HOVER over an any feature, like an Extrude operation, the pop-up window info offers limited use. It should also show me the depth extruded as well as any taper angle and what direction it was.
Knowing that it's "Extrude 1 / Component 6" is wonderful, but better would be: "Direction: Symmetric; Distance: 2.00mm; Taper: 0•"
Or Fillet: "Radius: 0.25mm; Type: Constant".
At the moment I need to then click "Edit Feature" to see the details. Would save time... and reduce finger-to-mouse-impacts.
Alldaron
