Create a Joint that can make an object move and rotate on a path..like a pattern
Please create a joint that will allow an object to move along a path and rotate with the path direction similar to a pattern with path direction checked (like a train on a curved path). This will be very helpful and used by a lot of people. This is a highly requested feature. Please consider this and if there is a reason this isn't being done please state that reason.
1 Comment
lure23
I believe this is already discussed in Curved Slider Joint (Mar 2016).
The best way to make the feature come through is to place the votes there. Having duplicates simply dilutes the votes and makes it /less/ likely that the feature is implemented.
