CORNER AUTOOFFSET OTPION CAM
Hi
It would be nice having an option or tool in CAM that would make extra cutouts around the corners in order to assemble the object in better precision. What I mean is- if I use ø3mm bit the work is faster but I won't get sharp corner and because of the 1,5mm radius I won't be able to put the parts together all the way.
I found my self struggling with sketching it manually which takes a lot of time and it makes the sketch much more complicated and it often slows the program and the whole work.
I hope the picture will get you into the picture 🙂
Thx
Screen Shot 2016-09-09 at 11.05.19.pngScreen Shot 2016-09-09 at 11.05.36.png
1 Comment
What I'd really love to see is a system for specifying tolerances and design rules so a user could make a single design, specify final tolerances (loose vs tight press-fits, sliding fits, etc), and then those designs could be automatically tweaked by F360 for machining vs FDM vs SLA vs...
