Hi
It would be nice having an option or tool in CAM that would make extra cutouts around the corners in order to assemble the object in better precision. What I mean is- if I use ø3mm bit the work is faster but I won't get sharp corner and because of the 1,5mm radius I won't be able to put the parts together all the way.
I found my self struggling with sketching it manually which takes a lot of time and it makes the sketch much more complicated and it often slows the program and the whole work.
I hope the picture will get you into the picture 🙂
Thx
