Constraints (Horizontal/Vertical)
Hey There,
It will be nice and productive to have the H/V constrains separated like in the old days. Or at least have the option to choose between "Separated H/V constrains" or not!
Thanks.
2 Comments
XanderLuciano
Heck, I'd rather have horizontal/vertical be the default over perpendicular. I can't tell you how many times I've wanted to change the angle of just ONE line and had 4 other lines move with it because they inferred perpendicularity. So irritating having to delete all those relations and manually add horizontal/vertical.
promm
Status changed to: RUG-jp審査通過
Thank you for your idea, this is getting archived due to research that was done to make the change from two commands to one.  The feedback has been more positive then negative.
Mike Prom
