COLLADA export
COLLADA export
Right now to export a Collada file for use with many other environments, include Apple's SceneKit framework, you need to export .stl, move it to MeskMaker, make it a sold, and then export it. The pieces are all there to integrate it directly, even if the export is cloud based
13 Comments
herzinj
Status changed to: 実装済み
Could you please provide me with a little more information on Collada, similar formats and where and why this file format is needed? We haven't heard this request yet, but I am open to hearing more about it and looking for input and votes from others to add it in if necessary. Thanks! James
Collada is a widely used and common interchange format for 3D files. Your Meshmaker product supports output of it from an STL, but there is degradation going from Fusion to STL to Meshmaker solid to Collada.
I'm using it for pulling designs into SceneKit on iOS and OS X.
Other Autodesk products use it as well.
Collada is non-profit and described here  https://collada.org/
I'm a teacher, and our students are working with Fusion 360. We are using iBooks to create interactive presentations, and they require the 3D models to have a collada file. Now, I know I must export the stl file, put it in Meshmixer and export it there. However, we need to create more than 200 files!  This is going to take a while. We wish Fusion 360 incorporate the collada protocol for future use.
Sorry for the bump, but I just wanted to chime in and add my upvote for a collada export. Fusion 360 is a beautifully simple modeller and I'd love to use the models I make in it in other applications too, ie games and simulators. 3Ds and Collada are the two most common support 3D model formats I know of, and Fusion 360 supporting their export would really make life simpler for myself and many others like me.
colin.smith
Status changed to: RUG-jp審査通過
Our translator does not support this today.
Archiving due to lack of votes.
I'm also very interested in this format being supported. As DAE is what I normally import to my other software. At the moment I can't even see there being a obj format even. Are there any plugins for other formats?
MartinMajewski
I am also very interessted in this export feature!
I like working with Fusion 360 because of the modelling-precision, but I would also like to export my models as poly-modells for example for scene kit on iOS / OS X. For this purpose I need a Collada daz / dae exporter and I don't want to use detours over other applications.
Every other Autodesk poly modelling tool supports Collada, so should also Fusion 360!
Upvote!
I'm also very interested in collada export
Another vote from me for enabling collada export
Collada export please!
Swany42
Collada Export please. I'm building Augmented Reality apps using iOS SceneKit. Would love to use Fusion 360 for the modeling. I will be making a lot of assets so a direct export (versus multi step translation) is required.
Upvote
mike_deborde
Upvote
