Changing line weight and font size
Hi everyone, pretty much explained with the title, but it the drawings look pretty ugly with the current state of line weights and
the inability to change the size of the font when making drawings from the model.
The line weights could be preloaded into different international standards for specific regions and customisable too. Perhaps allow the user to also use fonts that Illustrator, Photoshop, MS Office etc uses
30 Comments
O.Tan
don't forget custom drawing scales as well! Sometimes I need it to be 1:0.95
Dimension text size and font can be set, but options are limited. Frustratingly this doesn't affect Section letter sizes and other callouts.. and also cant be changed even in Autocad for some reason..
When I used to use ArchiCAD a few years ago, I remember needing to adjust the line weights and even colour near the start of the document.
Being able to change the colour would be quite useful too I suppose.
In addition to all that's been said, I second this post too.
Drawing issues
TimeraAutodesk
Hey All,
Great points, thanks for posting here. A couple of notes:
- The seemingly 'limited' options for text height are actually intentional. Depending on if you are in ASME or ISO standard of drawing, we only expose Annotation Text Heights that adhere to that standard, which helps make standard-compliant drawings super simple.
- Fonts can be found through the Annotation Settings as well, and you do have a wide variety of system fonts available to use, as you mentioned. Is there something else in particular that you're looking for, or does this solve your request?
- The ability to assign layers that define line weights and styles is definitely on our roadmap, and I anticipate we will get to delivering that functionality in the spring of 2016.
Hope you find this helpful, please don't hesitate to let me know if I've missed anything or if you have more comments/questions!
Best,
Timera
TimeraAutodesk
Yes that answers the font and scaling issues, thanks!
Then could the annotation size used for sections be looked at? they cant be changed and dont change with the overall settings. Seems like a bug then if they are supposed to follow the correct sizes according to the drawing standard.
Niels
TimeraAutodesk
@Anonymous Yes absolutely. Section and Detail view annotations are always 1 size larger than dimension text until the largest size is used by dimensions at which point all annotations use the same size. This is one of our 'fit-and-finish' items that's on our list to get out the door here in an update soon.
Timera
At least for the short term and temporary quick fix, please consider making default fonts size at least 12 to 14 points for everything.
At this moment, Fusion 360 has a VERY poor user iterface.
benoitD336P
It's November 2016 where is the Line weights options? Is it coming any time soon?
TimeraAutodesk
@benoitD336P - thanks for following up with us on this. The team is still working on this feature, and they have made good progress. We hope to be able to release the layer manager in one of the next major Fusion 360 updates.
Thanks for your patience!
Best,
Timera
corey.atx
I have two issues with the font selection and rendering in the Drawing environment.
First, the font selector doesn't actually let me choose an individual font (file), just a family or typeface. I have a license to DIN OT that I'd like to use, but Fusion 360 automatically grabs a condensed variant with no way for me to select that I'd actually like the Medium or Regular variant/font. The result is awkward:
That should look more like this:
The second issue I have is the spacing. Fusion has a rather rudimentary font rendering engine that doesn't seem to correctly space type. Even the default Arial renders with fractional values encroaching on the integers' space, and other fonts are worse still, such as in the first example.
Dear all,
can the weight of the lines now be edited?
thank you
Oliver
I still can not find any info that the line weight can somehow be edited in Fusion 360. I'm looking all over the internet but I cannot get it.
benoitD336P
@Anonymous unfortunately they only came up with that silly check box to activate line weight, I frankly can't see much of a difference between with or without it my prints still looks aweful and bloby. Love the software in general but hates the drawing that comes out of it 😕 it's like the print option, it came with a couple silly check box with zero practical options with it.... I hope they will finally work on those to finally have professional drawings come out of Fusion
studmuffpaul
I love how this post is labeled "Solved" yet there is no way to change lineweights in the drawing. The lineweight selection when you print makes EVERY line bolder including title block and profile lines in the isometric view rendering it totally useless unless your boss has bad eyes and uses a big button phone..
Can the solved thing be undone? This deserves attention as the drawing portion of Fusion is what needs the most help in my opinion.
Paul
benoitD336P
@studmuffpaul, I totally agree with you, he drawing portion of Fusion is terrible and really not professional. They are autodesk, they know what it needs to be like, I'm ashamed every-time I deliver drawings to suppliers how bad they look!
It seems this is an autodesk policy, that's the intent. Because they do not respond to these comments at all, but they react quickly to other trivial ones. I do not understand it, but it is a great shame, because this good product is degraded by this. Probably they do not want Fusion to spread much, because Inventor sales will drop, for example.
benoitD336P
@Anonymous, that's exactly my thought! So why bother making this software in the first place, especially this good fro everything else!! SMH!!
