I have a problem when running my CNC-router (X-Carve) in hard wood like oak. When the router reaches a tab it stops and lifts the bit to the set height for the tab. This causes the bit to burn the wood and make a mark that is hard to remove..In order to avoid this I would like the CAM program to create a tab that has a chamfer on each side, in order not to stop at each tab. I know that there is a tab shape that is called triangular, but this one is to weak at low hieights and to long for sufficient function. Please create a third type of tabs. I have made a simple drawing which illustrates the tab shape that I want. https://a360.co/2J9UG97
