2D Contour Tab Remove
wh6Q9NU
wh6Q9NU
Somehow I can't seem to find a way to remove just one tab from  a 2D Contour. In the attached image there are only two tabs and one can easily recreate both. But in a more complex situation with lots of tabs I can't seem to find a way to remove just one tab from a position. (Selecting a point and pressing button Delete and clicking the error dialog that pops up actually crashes my Fusion 360).
Has anyone an easy solution to this? It must be simple UI thing I gues. Thanks!
daniel_lyall
Hold the shift key down and select the point of the tab you wont removed.
A lot of the time they add stuff into fusion, key commands is one of them like useing shift, ctrl and alt to do a action if it is not 100% they do not saying any thing at all, but it may work when you try it.
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
