It would be perfect to simulate and generate the model about Computational Fluid Dynamics.
For example we can describe mass flow rate, volumetric flow rate, boudary of fluid region, density, heat, characteristic of flow like laminar or turbulent, and may be we can add dimensionless number like Mach Number, Froude Number, Reynolds Number and Weber Number with preview tab as Advanced CFD. We an also describe starting and ending cross section areas as Preserve Geometry and we would be able to generate the model with Static Stress and CFD analysis at the same time.
