Show only
Search instead for
It would be nice to select the center of a Spriral Tool path like an Entry Point. When you select a sketch circle or Model circle, you get the center point.
I get your point : ) sorry... anyway, These operations find the center point without needing a sketch. The Sprial tool path is different.
Selecting the Center Point for a WCS
Drilling Op
Pre-Drill Position
Measure
Maybe it could have the same pull down as the Drill op? Center Surface or Center Point? The truth is, I'm Lazy. I don't like going back and forth from CAM to Model to create a point, then get to recalculate all my Ops.
Hey there! Thanks so much for submitting your idea. Unfortunately, this idea did not get a lot of votes from the community, and now is 2 years old. We're changing its status to archived. If you still feel strongly about this idea, you can resubmit it. Check out some idea submission best practices here: https://forums.autodesk.com/t5/community-faq/ideas/m-p/5384681#M44
