I would like to be able to select faces or other model features to reference the WCS origin inside the CAM work-space.
In my previous CAM software (Gibbs) I was able to set a model face or vertex as the origin for a given axis.
This would be handy to have in Fusion, the closest implementation I see is to add a point to your CAD model then select that point in the WCS menu. This method works okay for simple cases but in my view it seems more like a brute force work-around than a proper solution.
The reason I would like to be able to pick a model face/feature is to make using work stops in milling more convenient. Currently if I have a work stop in a milling vise for my X axis reference point, that work stop might not always be placed against a feature represented by the generic points offered by Fusion's WCS Model/Stock box points.
Attached is an example part that would benefit from this. When milling the top face I want to have the work stop on the left bottom face. Unless I am mistaken, the only way to select that face as my X axis origin would be to add a point in CAD then use that point in CAM as the origin. This works fine, but I'd prefer to reference a feature directly on the model.
