CAM Improved centerpoint selection on radial and spiral operations
Radial and spiral operations ask you for a centerpoint but if you try to select the centerpoint of the circle you are trying to cut it will select a point on the perimiter of the circle.
Because everybody natrually wants the centerpoint of their radial cut to start at the edge of the circle they are cutting.
Sometimes I can just not select a centerpoint and select the circle as the machining boundary and it will automatically make the center the centerpoint but sometimes it doesn't work. I have resorted to sketching a centerpoint to use. This is a huge waste of time and it's rediculous that you shoudl need to. When you select any curve it should highlight a selectable centerpoint just like you see in drawings and other areas.
6 Comments
fonsecr
Thanks. I opened ticket #CAM-979 for this issue.
schneik-adsk
Status changed to: Gathering Support
yoshimitsuspeed
I don't see how this shoult need to gather support. I would think it would be seen as a bug or error on design that would be fixed in the next update. It's very inconvienent even if not a lot of people use CAM or go out of their way to vote on it.
al.whatmough
Status changed to: オートデスク審査落選
You are correct, this is more of a "BUG" then an improvement request.
al.whatmough
This was fixed in Invnentor HSM.  However, the fix didn't make it to Fusion.
They team just push the fix to our internal build of Fusion.
It should be customer facing in the next 30 days.
al.whatmough
