A quick CAM idea that would be very useful.
How about being able to visually manipulate/tweak the CAM toolpaths with your mouse (after the CAM paths have been generated with the editor)? In the same way that you can Push/Pull and extrusion with your mouse, using the Push/Pull arrows, it would be great to fine-tune the toolpaths in CAM by right-clicking your mouse to make the adjustment. The changes can be made visually or a simpler dialog box (similar to what is appearing in CAM edit already, but simpler), would allow for numerical changes. Just right-click on the toolpath and a simpler dialog box would appear to change standard settings
I think this would be great for:
- tweaking individual lead-in and lead-out paths/arcs/lengths - which would allow for more 'creative' fixturing, or if you are simply trying to avoid hitting a fastener.
- Adjusting feeds in certain toolpath zones
- applying bezier handles to toolpaths for more accurate tweaking - especially useful for defining where the tool enters and exits the path
- allow for tighter nesting of parts
Just a suggestion - not sure if this was discussed before. The idea came up when struggling to 3D Contour organic surfaces that intersected with geometric ones, and wishing I could just move a couple of the paths with my mouse. This would be designed to help tweak the toolpath after it's been generated.
Dave
